- Aug 29, 2004
Ok dumb question time....anyone know how to access the Setup menu on the HD-A30? When I turned it on the menu never showed although the display said it was displaying the menu....after a while it just skipped to ready. This was over component using the optical audio out. The unit auto detects my settings mostly correct but the audio needs to be adjusted. Thanks for any help guys.
