The Chosen One
- Feb 4, 2001
Hi guys, im running WinFax Pro on a fax-server machine, and all other computers in the office are connecting to it over the network via the Fax-Client Sharing option. All other comps are able to send and receive faxes fine, except one.
On this one, whenever i try and setup the shared Fax Client, and point to the fax-server as a host, it responds with a "Setup Cannot Connect to WinFax Pro on Faxserver (Reason: Access is Denied). Check that this is the correct host name."
I dont understand why i get this error.
Ive tried disabling both firewalls....nothing.
Tried enabling the firewalls with exceptions for WinFax (windows firewalls that is).
Tried Re-installing WinFax on teh client machine.
Nothing seems to work, yet every other machine works fine.
Does anyone have any ideas what might be causing this?
Thanks,
Thanks,
