AC68U Merlin Firmware 384.14_2: Issue with RDP & OpenVPN
csnv
Hi All,
First time setting up openVPN, easy so far until .. i hit a brick wall... for the last 2 days, i tried my best searchin all over internet to try to fix this one issue i have with using RDP to a lan machine from my phone through openVPN.
Here is my progress:
  1. Make sure the RDP work on win10 machine (192.168.2.122), check. I can log on fine with my phone using local wifi.
  2. Make sure I can connect to openVPN, check. my phone (10.8.0.2) can log on and go on internet my IP is WAN ip and I can access to the internet and the AC68U server.
  3. Make sure I can ping/RDP the win10 machine, not working <= where i'm at.
any idea?
I'm not sure what the Merlin interface looks like, but I've set up quite a few OpenVPN configs on those Asus AC68 units.
Here are the settings I generally use:
What client app do you use for android (that supports TAP)?
OpenVPN Connect?
Honestly I don't use it on mobile much, usually on a laptop or something. But it should work from that app, that's the official app as far as I can tell.
