itshardtochoosealcd
- Oct 8, 2006
Hi guys,
I am thinking of buying the NEC ea275uhd. I already tried the Dell P2715Q which had uneven white uniformity across the panel. From the center to the bottom, it had a yellow tint. I was wondering if this could also happen with the Nec ea275uhd because it's not the pa series.
Also, is the NEC displays warranty good for all of North America? I'm thinking of buying the monitor from bhphotovideo but if I have a problem, can I just call NEC Canada and they will service it? Furthermore, what is the dead pixel warranty with NEC?
I will connect it to a retina macbook pro and use it in scaled 1440p mode. Someone told me that it won't do 1:1 pixel mapping in lightroom...is it true? is that a problem?
Thank you for your help.
