Background:
Few months ago Ive picked up a cheap 120gb M500 SSD drive to upgrade my trusty 64gb M4 SSD on my main rig (win7 64bit).
Instead of big hoopla of fresh install, I would prefer to clone it to the bigger SSD drive. Later I want to upgrade my HTPC HDD 80gb IDE HDD to 64gb M4 SSD.
The HTPC (win7 32bit) supports AHCI so I should have no issue with an upgrade.
I got some tips form my friend how to do it, I just want to run it by [H] to make sure I dont screw up something. He recommended to use DiscWizard free software and use disk instead of partition cloning option.
Questions:
I believe SSD to SSD full disk cloning to should be straight forward, after all it should take would be to disconnect smaller SSD and point BIOS to boot from new SSD.
Is this correct?
For HDD to SSD, I should remove as much junk as I can from HDD. (to make sure it is less than 64gb).
Is it recommended to defrag HDD before performing disk cloning? Do I have to worry about page file enabled on current HDD install?
Will win7 32bit adjust itself after first boot from SSD?
Any comments/tips would be much appreciated.
Thx.
Questions:
Is this correct?
Thx.
