Abit Motherboard
Kajun614
Was cleaning out my old PC that sits at work. Saw the motherboard and it brought back some memories. Abit IP35pro
Never had an issue with that computer. btw think I removed 2lbs dust from inside the case.
lol
Thought id share im sure others remember Abit or still have em in use.
dlseb
WOW, that is like a voice from the past. I loved their boards. Does bring back a lot of memories. Thank you
nofearek9
i was always using abit motherboard (i remember i had a cyrix 6x86 with abit motherboard )until an8 32x ,bought one died with code 9.0 if i remember correct ,bought second less than a year died as well so jumped to asus till now.
Fix Me
I just retired my Abit IP35 Pro last year. It was my main PC, then my backup PC, then in my arcade box until it got cycled out for "newer" hardware.
D
Deleted member 184142
Guest
jlbenedict
my last ABIT board was the AN8 SLI... I believe that was the first motherboard that I actually had described as "sexy"..
Niner21
I used a few Abit Intel motherboards in the past with no issues. I remember my NF7 AMD board the most. Great memories.
CAD4466HK
The last Abit mobo I had was a VT7 in conjunction with a P4 2.8B as a cold storage file server. I turned it into a Bear Share/Emule box and sold it.
