A8N32-SLI Deluxe RAID driver issue...
Majeztik12
I for some reason cannot get a RAID-0 config to work. I have enabled the BIOS settings, used the ASUS driver cd to make a 32bit SATA/RAID floppy. To no avail! Am I missing somthing here? I hit F10 and it says I have a heathy array. It also says its not bootable??!! Please help! Thanks.
nooh
Have you read the manual , also check the drivers installed properly and assigned properly
Majeztik12
I went to ASUS web site...guess I need to flash my BIOS to ver. 1205 for "enhance SATA RAID compatability". Guess I can use a IDE drive load/flash. Go back to RAID-0 config again...lol. Thanks for the help!
kvn5000
you could also use a different computer, get the bios and flash program on a floppy and do it from startup. no reason to switch everything around to flash a bios.
Make sure you put your current bios on the floppy incase something goes wrong.
