I have a few questions about the chipset fan on A8N-SLI Deluxe motherboard.
How noisy is the so-called replacement fan?
The motherboard I bought came with the newer fan installed already but I am thinking it may still be noisy.
Has anyone here replaced the chipset fan on the A8N-SLI Deluxe with a passive heat sink such as Cooler Master PAC-P01 or Zalman ZM-NB47J?
How is the temperature with the passive heat sink?
Do you use an additional fan on top of the heat sink?
The processor I will be using is an AMD 64 X2 3800+ and I may overclock it from 2.2 to 2.4 GHZ.
Thanks.
Thanks.
