I'm helping my friend Oc his CPU only in his new rig.
Hes running an Asus A8N-Deluxe sli mobo
a 3200+ venice (1.45V, 10x, 2.0ghz stock)
Corsair value select 2x1gb sticks
I've been researching/reading his manual for his mobo and Ocing his Cpu with stock HSF should be pretty easy.
I'm hoping for 240mhz HTT bus for a 2.4ghz clock.
I want to keep the memory at 200mhz and not fool with its timings. (the manual says it has a maxfrequency for memory and setting it to 200mhz should work just find and auto on the rest of cas/timing options.
WHat would you advise as a voltage for the CPU to to reach 2.4ghz? 1.55? 1.6V? I'll have him prime95 to check for lowest stable voltage after he reachers 2.4ghz.
Will I need to up the chipset V any for 240FSB?
ANd I won't have trouble with memory dividers or anything right?
thanks.
thanks.
