I know this thread really could be placed in the AMD or Motherboard specific forums - but as this pertains directly to overclocking but generalizes the way the parts operate - I figured I'd stick it in here (the Overclocking forum).
I've got a variety of questions that have been plaguing me in my attempt to overclock my new machine (specs as per my sig below). I'm trying to come to a finer understanding of how the guts behind the machine work, in an attempt to better quantify and tune my overclock.
I understand that with Athlon64's the memory controller is in chip. My current ram is rated 2-3-3-8 @ 2.6-2.8v and 2-2-2-8 @ 3.2v. I've tested and confirmed both speeds with memtest while running at default/stock/auto settings on the chip/motherboard - and am pretty confident that it's fully capable of those speeds.
Yet I've seemingly hit a threshold between 275 and 300 HTT - where either the memory or the memory controller are starting to flake out. This is where and why I need to become better educated in order to make some informed decisions about what I change or tweak in order to increase my stability (currently capable of 300 HTT x 9 multi @ 2-3-3-8 3.2v desktop and gaming stable, but it is not by any stretch Prime stable - which has me confused). I've been able to run the machine at the 300 HTT with relatively tight timings (2-3-3-8) and the machine is "day-to-day" useable (gaming, workload, etc). Lockups or crashes are nearly non-existent, or at least rare enough that further tweaking can fix that - yet Prime95 (using 24.11 beta which fixed a lot of A64 errors I was getting previously) still won't run for more than a few minutes stress-test without giving me hardware, sum, or rounding errors.
So, am I guessing correctly when I assume that as long as ram is running within spec no latency/speed adjustments are required? ie; if PC3200 is running in/around 200mhz spec and it's rated 2-2-2-8 @ 3.2v (and memtest confirms it'll do 2-2-2-8 @ stock 200 HTT with no errors) then if 300 HTT is applied, but the divider is dropped to 2:3 or to keep it at or below 200mhz it should still run 2-2-2-8? Or am I guessing wrong and infact the increase in HTT, no matter the memory speed - requires a bit more leniency in the ram (therefore requiring me to loosen the timing/latency on the ram to 2-4-4-10, or even 2.5/3.0 -x-x-x in order to maintain a stable 300 HTT overclock)? Or would loosening the timings to those mentioned simply be in order to overclock the ram past it's stock speeds?
Or is it just not as simple as that - and very subjective to both ram, chip, motherboard, voltage - etc - meaning I'm not going to be able to quantify it in such terms?
I am also correct in understanding that the LDT voltage is for the HTT controller? If so, bumping voltage on this would be in proportion to a higher clock HTT (and if the HTT multiplier is dropped, would the voltage still need to remain raised?). Or would it only need to remain raised if you were technically overclocking the HTT past 1000mhz?
The chipset on the other hand, controls what? Where and why would the increased voltage on the chipset be required, and what would it proportionately or inversely effect?
I'm trying to understand how each of these parts affects the stability of the machine as a whole - past the relatively simple HTT & CPU Multiplier portions of overclocking.
