first of all, why would you wanna ditch a xp90 for the x2 heatsink? theres no cooling performance gained there and socket 754 and 939 both use the same mounting method so the x2 heatsink will work fineCRXican said:I'm trying to find out if the X2 heatsink will work on Socket 754 cause I wanna ditch my XP-90
The X2 heatsink is OEM, it's cool and my XP-90 sucks for the hype it gets. Either that or my 3700+ is a furnace.N H O said:first of all, why would you wanna ditch a xp90 for the x2 heatsink? theres no cooling performance gained there and socket 754 and 939 both use the same mounting method so the x2 heatsink will work fine
XP-90. It can also use 90mm fans which should be quieter.Blehh said:What's bigger, a XP-90 or the X2 HSF?
Juic3 said:http://www.madshrimps.be/?action=getarticle&articID=399
Thats a comparison between both, but the reviewer tried an 80mm fan on the xp-90 "to make it fair". Someone at anandtech forums did the same test but with the xp-90 w/90mm fan and was impressed by the results too.
JMke said:I compared the X2/Opteron new heatpipe cooler (4 pipes) to XP-90 and XP-90C and some other 20 heatsinks here: http://www.madshrimps.be/?action=getarticle&articID=406
Absolute0 said:I've been saying for a long time how XP90 was totally overrated, but no one believed me.
That fan has three operating modes: low, medium, and high. The CFM is measured at "high," the db is measured at "low." I've got a bunch of those and know for a fact that they aren't putting out 29.8 db at high (although they do move a lot of air).wrangler said:
Retsam said:There was a person recently who pointed out the 80mm to 120mm FAN ADAPTER such as HERE. If you didnt like the stock fan, you could always stick a quieter 120mm fan with an adapter on it.
I dont know what people are talking about anyways with it being loud. I have the freaking heatsink and its silent @ 2500rpm.
They're pretty rare now and the prices have jumped a bit.wrangler said:You can find them on ebay. Theres a thread somewhere here that has a link but I can't find it. I got mine for 5 bucks plus shipping for a total of $15.
Make sure when your looking that it is the 4 pipe Opteron/X2 cooler. Some of them are advertising X2 coolers but it's the one that comes with the 3800+ which aint the same, and there is a 2 pipe cooler also that I don't know where that came from.
Retsam said:Actually I think ive just decided to go ahead and buy that 80mm - 120mm fan adapter. Im interested to see if it will cool the stock copper heatsink better Its actually about $5.50 total for me with first class shipping from svc.com. Ill take a chance. Ill do some benchmarks after and let ya know how it goes.
IanG said:XP-90. It can also use 90mm fans which should be quieter.
