Scotty_SFF
- Jun 2, 2006
Ctrl-shift-make lips more full? That's not how it works.If you're making it digital, you can easily change the lips and probably just make them a little bit more full.
Don't say anything about DD's face, im not liking it
Actually I meant you can smudge or redraw sections, where as with tradiotional paint you don't have as much liberty.Ctrl-shift-make lips more full? That's not how it works.
Not at all bad, good work.
However, you need some anatomy work, especially in the faces.
Mostly the eye placement and size.
Also when someone screams that much they usually have most of their teeth exposed.
Go to a mirror and yell AAAAHHHHHHHHHHHHHRRRRRR in it.
Its not OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO (Lips closed)
its AAAAAAAAAAAHHHHHHHHRRRRR (Lips peeled back with teeth exposed)
Also, the screaming guy needs an angry brow to match his expression. Its sort of like a sluggish fat man opening his mouth to eat something.,
Bring his brow out and angle it downward, raise the nose and add wrinkles.
It really helps to go look in the mirror and get pissed and try to copy your own face.
