A Team of 50 Engineers Spent 6 Months Making a Fidget Spinner
Discussion in '[H]ard|OCP Front Page News' started by rgMekanic, Mar 12, 2018.
  1. rgMekanic
    rgMekanic [H]ard|News Staff Member
    5,075
    May 13, 2013
    Mitsubishi Precision Co Ltd. designed and built a fidget spinner based on MinebeaMitsumi Inc.'s ball bearings to break the Guinness world record for "Longest duration spinning a fidget spinner on one finger." The team of 50 people spent 6 months creating and perfecting the design, with a heavy brass outer ring, and a lightweight aluminum center section, which spun for 24 min 46.34 sec.
    You thought it was over didn't you? You thought the whole fidget spinner thing was something you wouldn't have to hear about again. HA! The article does state that you can buy one of these rotating masterpieces from the Japan Handspinner Club for $450. NMB makes some seriously high quality bearings, couple that with the lack of battery and this one has almost no chance of exploding.
    "By incorporating technologies used for space satellites, we were able to realise smoothness and overwhelming rotation time that we’ve never seen before. We also applied bearing manufacturing technologies used for aircraft as well as wheels and rings. We use materials with the highest strength among aluminum alloys and highest quallity brass so that wheels and rings are thoroughly thinner and lighter than conventional ones," - Shigeru None.
    sleepeeg3 and janas19 like this.
  2. Jovian
    Jovian Limp Gawd
    341
    Jun 8, 2004
    Holding my hard out that long would be painful
    THUMPer likes this.
  3. rgMekanic
    5,075
    May 13, 2013
    I believe you're still safe, it's 6 hours before you should consult a doctor
    NeoNemesis, mord, craigdt and 17 others like this.
  4. Absalom
    Absalom Limp Gawd
    465
    Oct 3, 2007
    The real value isn't in the spinner itself, but the technology and r&d that went into making it the perfect spinner.
  5. vinciblegod
    vinciblegod n00bie
    21
    Feb 26, 2016
    This is basically the same as that video of some aerospace engineers making the perfect spinning top, the point is to show off their engineering prowess.
  6. ZLoth
    ZLoth Gawd
    783
    Apr 13, 2010
    I'm about 20 years removed from being a machinist. You should google the specs on Timken bearings. Some of the specs can get interesting, especially with the maximum RPMs. I always got a chuckle whenever I reviewed the receipt from the bearing supplier, and the explicit disclaimer that it could not be used in missiles and nuclear reactor systems. Nope, just food processing equipment.
    janas19 likes this.
  7. alamox
    alamox Limp Gawd
    454
    Jun 6, 2014
    was that supposed to relief or induce stress... team of 50 engineers to miss the primary fonction of the tool...
    Spidey329 and rgMekanic like this.
  8. Spidey329
    Spidey329 [H]ardForum Junkie
    8,798
    Dec 15, 2003
    But what if my food processor is located inside a nuclear reactor?
    cyclone3d and rgMekanic like this.
  9. oldmanbal
    oldmanbal [H]ard|Gawd
    1,642
    Aug 27, 2010
    want to buy one for son but at $450 I'll pass. 20+ minutes will only find use so many times before it's just shelved :(
    I wonder what the wear down ratio is for a piece like this? I would assume due to the massive precision required and the attention to dust proofing the batch used, that it wouldn't take long to start degrading performance. Regardless, you might still be hitting 18 minutes 5 years from now, which wouldn't be anything to scoff at.
    craigdt likes this.
  10. Mike89
    Mike89 Gawd
    683
    Jan 27, 2003
    I've got 7 minutes out of my spinner (on desk). 24 minutes is insane. So is the price. Mine was $35, this one is $450. No way Jose. I was interested in spinners...........for about a minute. Now I take mine out every once in a blue moon and fiddle with it.
  11. Travolta
    Travolta Gawd
    627
    Sep 19, 2004
    What the article doesn’t mention is it took 50 engineers to make the spinner, but a machinist to fix it for them. Hahaha!!!!! (I’m a machinist).
  12. Chris_B
    Chris_B [H]ardness Supreme
    4,670
    May 29, 2001
    They're only about a year late with this.
    craigdt likes this.
  13. Mugato
    Mugato Muh Feelz!
    957
    Feb 25, 2014
    Misogynist. Did you see the "nerdy girls" getting smoked by those guys? Couldn't be that they are simply better at that...not at all.
  14. Gottfried Leibnizzle
    Gottfried Leibnizzle Limp Gawd
    200
    Apr 29, 2015
    Surely removing the holes from the disc would make it more efficient?
  15. Skylinestar
    Skylinestar Limp Gawd
    427
    Jun 14, 2011
    Having this in a laptop will save some precious battery life.
  16. Flexion
    Flexion [H]ard|Gawd
    1,469
    Jul 20, 2004
  17. Comixbooks
    Comixbooks Ignore Me
    11,372
    Jun 7, 2008
    Team of 50 people.......you can't even find these at Walmart anymore unless the Toy dept. still has them we even carried the replacement bearings from them at one time.
  18. Nebulous
    Nebulous [H]ard|Gawd
    1,384
    Nov 16, 2005
    I want one! Getting my checkbook ready...
  19. IcePickFreak
    IcePickFreak [H]ard|Gawd
    1,028
    Dec 1, 2010
    I find this ironic since Mitsubishi was known for crankwalk problems. Maybe this was a team building exercise to figure out bearings.
  20. Comixbooks
    11,372
    Jun 7, 2008
  21. Dr. Righteous
    Dr. Righteous 2[H]4U
    2,913
    Aug 1, 2007
    You are not having fun with your kids until you tell them to follow you to the garage with that fidget spinner.
    Then tell them "Ok, hold it like that"; then you hit it is 100 PSI of compressed air from the air gun.
    It takes off sounding like a turbo spooling up and they quickly get scared and start whining. It is hysterical! :D
  22. Fuzzy Logik
    Fuzzy Logik [H]ard|Gawd
    1,061
    Aug 16, 2001
  23. DejaWiz
    DejaWiz Oracle of Unfortunate Truths
    19,261
    Apr 15, 2005
    I had a fancy version of that 30-35 years ago. Even came with a stand. Ran me out of about $8.
    mord, Travolta and TwistedAegis like this.
  24. knowom
    knowom Limp Gawd
    304
    Aug 15, 2008
    cool now mount it on my rims...
