KevySaysBeNice
- Dec 7, 2001
Stupid/simple question, I know, but, here goes:
Say I have a webpage:
http://first.website.com/stuff.html which contains:
Is it possible to do this on a different website:
http://second.differentcompletely.com/getstuff.html
It doesn't SEEM possible... but is it?
fake edit:
So, as I see it, the ONLY three options to get data cross domain is:
1) Write a local server side page that takes in a parameter, which will load the contents of a remote page and then spit it back out, avoiding the entire client side cross scripting issue all together
2) <EDIT> I had mentioned using getJSON, because I thought it was somehow magic, but in reality i raelize that getJSON is just implementing $.ajax - so now I'm totally confused why this works:
Even though it's cross site... Is it because JSON is being returned, and as long as it's JSON it's all good in the hood? </EDIT>
OK, so, now here are some questions:
1) Am I right? Are those really my one three options?
2) Why can I use getJSON cross-domain, but something like .ajax or .get won't work cross domain? I realize that these are all jQuery functions, but if I were to implement ajax myself with the XMLHttpRequest object (or whatever), would I have this problem? I'm guessing this is a browser thing, that blocks cross domain calls. But again, why does getJSON seem to be able to access cross domain "stuff"? <EDIT>SEE EDIT ABOVE</EDIT>
3) BONUS QUESTION to show my complete ignorance: why, when you use google analytics, is cross site scripting not an issue? When you do something like event tracking, isn't that making ajax calls to google, on a different domain? And getting some data back? Or is it simply posting data, and nothing is being returned?
Thanks <3
Code:
<ul><li>some</li><li>stuff</li></ul>
Code:
$.get(
"http://first.website.com/stuff.html",
function(data) {
alert(data);
$('#lol').html(data);
fake edit:
Code:
var yql = 'http://query.yahooapis.com/v1/public/yql?q=' + encodeURIComponent('select * from html where url="' + site + '"') + '&format=xml&callback=?';
// Request that YSQL string, and run a callback function.
// Pass a defined function to prevent cache-busting.
$.getJSON( yql, cbFunc );
Thanks <3
