A return to AMD after 13 years
Discussion in 'Motherboards' started by M76, Aug 3, 2019.
  1. Azrak
    Azrak Gawd
    820
    Oct 4, 2015
    Which map?
  2. M76
    M76 [H]ardForum Junkie
    9,226
    Jun 12, 2012
    This one
  3. Azrak
    Azrak Gawd
    820
    Oct 4, 2015
    OK, wow, yeah. That map is terrible at the 4 way crossroad right at the beginning part (take a right out of the bunker). Stutter city. Seems to be the shadows. Use partial shadows or disable them completely and the frame rate is fine. Unless the problem you see is somewhere else?
  4. JRZoid
    JRZoid [H]Lite
    91
    Feb 1, 2019
    You chose wisely...should have no stability issues at 4.2...and not gonna worry about a few frames and a millsecond of frame timing.
  5. mvmiller12
    mvmiller12 Gawd
    736
    Aug 7, 2011
    Seeing as it is a mod, it might be worthwhile to bring the issue to the developer's attention so he can look at it. It could be there is a relatively simple fix to the issue the devekoper could put into the mod itself were he made aware of it...
  6. SvenBent
    SvenBent 2[H]4U
    2,976
    Sep 13, 2008
    I do not. But the principle remains the Same between the the different zen cpu's
    Cross CCX communication is slow and thread goings to the same physical cores due to SMT are ajitectural "issues" still being present
    The SMT issue has been an issue since the first core i7 aka its not a per chip issue but native issues from the architecture decision
    IdiotInCharge likes this.
  7. M76
    9,226
    Jun 12, 2012
    Reducing shadow detail did fix it, new version of the game is coming soon anyway that might or might not break mods anyway.
