just installed a bios that the XFX tech people sent to me to address my card doing the gray screen of death. it seems to be working but I am a little put out with their solution to the issue. first it raises the default GPU clock to 900 (25mh over) but then it decreased the memory clock form the 1300 (5200) down to 1015 (4060). so I get a 22% decrease in my memory speed in exchange for the 3% gpu oc. maybe I am being petty but I paid 430 for an overclocked card, not an under clocked card. I really didn't need a new bios for this either, I had already tried under clocking the memory I just had not apparently taken it down far enough (I was thinking that a "sever" under clock as being 15%)
at any rate I am going to test this out and see what happens when I return to stock clocks. if it will not run at the advertised speed I think I should RMA it.
I really do have to give props to the XFX support guy, I had not even contacted them rather they found my post and PMed me. (I usually only contact a company as a last resort) but I am not sure that I can handle the fix here. Is there any other alternatives here? I am quite sure that I will not have an issue returning the card, I just want to make sure that I have covered all my bases
