(lols)Includes 3x 18-55mm Zoom-NIKKOR VR Image Stabilization Lens with legendary NIKKOR optical quality and fast, accurate autofocus for vivid color, striking contrast and crisp detail and VR image stabilization to ensure the sharpest hand-held pictures and movies.
If you're going to post cell phone pics, that's fine, but at least post decent ones.
Thanks! already picked up Lightroom. I know Photoshop, but the sheer number of options and tweaks in LR is insane. Will take some time to really learn. I used FLickr because I want to try out the LR integration.Happy to see you're enjoying your D3100, Modred. Use Minus for uploads to get full sized shots. I would also suggest dumping the 18-55 kit lens and stepping up to a simple 50mm fixed focal length lens-that should get you started with your first foray into quality glass. The fixed focal length will force you to adapt to the lack of zoom by moving around and improving the composition of your shots.Finally, invest in a copy of Adobe Lightroom 4, by and far the best photo processing software for DSLRs.
I was actually eyeballing a few 40mm and 50mm lenses over at B&H, but need to do some research. I have a baby coming in March (hence the shower and cake) and will need something better than the stock lens.
