Monitor Guy
- Aug 3, 2007
Could someone explain to me in what circumstances you would use the adobe rgb preset mode opposed to using one of the full gamut modes?
I guess colormanaged applications like photoshop and firefox 3 will anyway translate your adobe rgb images towards the wider gamut when using a full gamut mode. Could the purpose be that non-colormanaged applications would then also be able to show adobe rgb images correctly or do they anyway read them out as srgb?
It would only really be useful if you are working in an non-color-managed workflow that was using an AdobeRGB colorspace. If you are using color managed apps, then you may as well take advantage of the full color gamut of the display and not be restricted to Adobe RGB for no good reason.
