It seems i have at least two dead pixels (one red in the middle + one green in the upper part) what can i do ?
Another question: where can i buy a spare support foot ?
It' s true that the dead pixels are not SO visible if i don' t search for them, when looking from sufficient distance. (Thanks to the resolution.)
But they are not invisible. Especially on uniform background, and one of them is a stuck green subpixel i can see easily on a black background.
I unsuccessfully tried using PixelRepairer & UDPixel (don' t know what' s the best frequency setting to use ?) for a whole night.
I' m wondering if it would be a good thing to try replacing it ?
It' s a bit annoying for a brand new panel of this price to have defects :/
But i don' t want to sent it back and paying the huge transport fee for getting an even worse/used/scratched/refurbished model...
Do you know what is NEC' s policy about that ?
Except that it' s a wonderful screen !
Work great with games and even video.
(Nice catch on the LED intensity setting.)
...with SpectraView Profiler (licensed from BasICColor). With SpectraView II you can also access the LUT of a PA model.I also read that european Multisynch are firmware locked to prevent hardware calibration
I'm really wondering if someone have ever got a screen without dead pixel.
POST if you have one, i'm curious.
And last but not least, the fifth display had 4 or 5 stuck sub-pixels. Also of note, the last two displays seemed loose in the monitor housing at the top and the bottom edges of the screen. It is possible that first through third displays also had this 'issue' but I can't say that I noticed it.
That's intended – in particular to avoid thermal tension.Also of note, the last two displays seemed loose in the monitor housing at the top and the bottom edges of the screen.
Just thought I'd chime in concerning my ongoing experience with the NEC PA301w-bk-sv.
As of current, I'm awaiting my 6th replacement from B&H...
