Lots of drama tho![]()
Yeah, just pointless drama. It's not like things that are hurt most by this flaw (data centers) mostly run on Linux.
Then people are free to suck up and take the performance hit. I offered a very good solution. I have bookmarks. I use the same websites day in and day out. If I do visit new websites and somehow get infected then the following day when I re-image my drive ... I'm good to go.
35% performance hit? If true ... that's a devastating amount of lost performance.
I'm just not going to suck it up and take the performance hit.
There is nothing I do on my computer that I have to worry about.
All my financials are handled strictly on my phone. I get email alerts for every transaction. Maybe the rest of you are exposed. I'm not.
Even if it is limited to 5% (more likely 10% as it's a lot of sql calls), all those corporate servers running on the cloud will be affected. Considering clock limits on Intels HEDT's, that means AMD is on par performance wise, more than ever and for less money.
Cry in your soup Shintai, you know it's true.
In other words, this confirms AMD is not affected.
49% performance penalty on EPYC 7601.
Nope.
Nope.
AMD was authorized to be excluded, only effects Intel so that tweet is pretty much meaningless and confirms the problem is not a issue for AMD.
Nope.
Nope.
of course you can always consider non ITX builds?
There is a ROG and Fatality ITX board for AM4, I am sure they are not garbage.
That is an outright lie. AMD is unaffected, and their patch was accepted into the mainline kernel.
So what's the alternative for somebody who wants to build a mini-itx system?
It looks like all of AMD's AM4 mini-itx boards are complete garbage.
At this point maybe I should just start investing in an ARM SOC...
Glad this doesn't appear to affect gaming, but man, what a crazy situation.
Based on Computerbase's initial testing, there isn't a noticeable difference. I posted the link in the Front Page thread.
Linux Kernel as of now still treats the AMD as insecure so it suffers the same penaltys. Obviously you can bypass this on boot for both Intel and AMD. Of course, this will all be sorted soon.That is an outright lie. AMD is unaffected, and their patch was accepted into the mainline kernel.
This is because the initial patch hit all 64bit Processors, AMD had already released a patch to fix their end.
Exactly, all x86 CPUs are treated as insecure in the recent kernel. If a patch is added to exclude AMD CPUs and when it is added to the kernel remain to be seen.
And what's the windows option?Every single server, in the world, will add nopti=true to AMD systems. Server Owners aren't dumb end users. To post a EPYC benchmark claiming poor performance, or in any way insinuate AMD is impacted by this, is pure and utter bunk.
Consumer products do not appear impacted much. This is a non story for consumers.And what's the windows option?
Enterprise customers use Windows too, you know.
Not at the scale of *Nix.
"describing software analysis methods that, when used for malicious purposes, have the potential to improperly gather sensitive data from computing devices that are operating as designed. Intel believes these exploits do not have the potential to corrupt, modify or delete data."
So they can gather the data, just not modify it? It's not extra extra bad, just extra bad?
"Based on the analysis to date, many types of computing devices — with many different vendors’ processors and operating systems — are susceptible to these exploits."
Look over there, a three headed monkey!
"Intel is committed to the industry best practice of responsible disclosure of potential security issues"
...which is why we kept quiet until others found out and let our CEO cash out before shit hit the fan.
"Check with your operating system vendor or system manufacturer and apply any available updates as soon as they are available. Following good security practices that protect against malware in general will also help protect against possible exploitation until updates can be applied."
Which is it? Do you believe it's exploitable or don't you?
I've also noticed the loud silence from Anandtech.I noticed AnandTech has been completely silent. They must be waiting for the official Intel fluff-job press release that they can post verbatim to explain that all of this is GOOD for us and we should want MOAR of it from Intel.
https://newsroom.intel.com/news/intel-responds-to-security-research-findings/I've also noticed the loud silence from Anandtech.
