Originally posted by jpmkm
Yeah, epoxy is fucking strong. If you can break it out easily then you didn't do it correctly in the first place.
Well, I don't use caffeine or anything like that. I just used fucking as an adjective to help show how strong it is, not how true the statement is. If you would like me to rephrase that, then epoxy is really strong, and if it breaks out easily then you did it wrong. It's true because I've used it and it appears that several other people on this board have used it without problems.Originally posted by Ruckus
And the swearing makes it true huh? You need to lay off the coffee.
Originally posted by nurv
Use double sided tape?
