A from scratch Aluminium case... very different and meticulous quality.
Mitsimonsta
Oldnewby has gotten back to me with full specs:
Oldnewby @ OCAU said:
Complete details are as follows:
  • Q6600 @ 3Ghz
  • Asus P5KE
  • ATI 3850
  • 4GB Corsair 800 Mhz
  • Compro Dual tuner TV card
  • OCZ Core series V2 30 GB SSD (soon to be changed to Vertex 60 GB SSD)
  • Seagate Momentus 250 GB 7200 RPM drive
  • WD 500 GB HD.
  • Antec Neo 650 watt PSU
  • Noctua UH9 heatsink and fan
  • Windows 7 Build 7057 64 bit
Having said all that, by far the biggest noticeable
difference I've seen over the years in everyday use,
using various CPU's, RAM etc is the move to SSD, but
the core series is showing signs of "stuttering" so this
needs to be changed to a better SSD.
Hope you find this useful.
Regards, oldnewby.
Mitsimonsta
The wood carving has begun :D
The back side. Removed as much material to reduce weight, but ribs kept for strength.
The front side. Ground down using an angle grinder with a special abrasive disc.
And to give you an idea of how it will eventually fit...
silent-circuit
To put it simply, I think the wood is going to ruin it entirely. It looks very nice now, and unique. It's just going to be a wooden box with some rather rough, forced looking curves once he adds the panels.
[H]adouken
Hmm, why do all the fancy aluminum work when you're going to wrap it with wood? With that much detail I figured the case would be left alone...
