Well, I'm probably going to purchase some stuff from DangerDen tonight. In particular a new top for my TDX (for A64), a BIP2, and a D5. Now, I currently have an Eheim 1250 stockpiled (moldy >_>) that I could potentially use, but that thing is a behemoth. I can fit it, but would it be worth it to go with the D5? Is it a lot quieter?
And my other questions are as follows:
Is there a large difference between the BIP2 and BIX2? They both seem fairly similar, and the pricetag on the BIP2 is definitely appealing. Which should I get?
Will the TDX perform well on the A64? It did really well on my Athlon XP a couple years ago, but I was debating getting a Storm or Apogee instead. Obviously it's just more cost to get a new one, but if the performance will drastically improve, that would rock. I save about $30 getting the TDX top over the Apogee, and a good $65-70 for the Storm.
If you need some background info for what I'll be doing, it's essentially OCing 'til the break of dawn . And there will be a Maze4 GPU block in the loop as well.
Thanks,
Alex
Thanks,
Alex
