I have this problem where the A drive wont refresh after putting in a new disk. So what happens is the user will put in a disk at start up, the A drive reads it and displays the contents of the drive. The user then copies something from it or puts something else on the drive, after it is ejected the contents stay in the drive folder as if the floppy is still in the drive. After that if I put a new disk into the clients computer it wont read the new disk, but will continue to display data from the old disk.
Things I have tried:
I have tried uninstalling the drive from the device manager and reinstalling it, I checked to see if there was something wrong with the drive by going into dos and inserting multiple disks to see if it would display all of them(it did display all of them). The one thing that would work in windows was going into the device manager and disabling the a drive, and then renable it, the drive would then refresh and take a new disk, but if a new disk is put in after that the steps would have to be repeated.
The specs of the machine are
pentium 4 with hyper threading
memory 1GB-2GB(cant remember exactly)
windows xp pro
hard drive is 80-160GB hard drive.
Any input would be helpful, since I am a little stumped on it. The only thing I can think of is reimaging the pc(and that is to time consuming for the client).
windows xp pro
