Just in case anyone else is interested in mirroring their OS drive without wasting too much drive space, I may have found a solution to this. When I first bought all the hardware, I decided to go with this external HD enclosure for the mirrored OS drives. For one thing, my motherboard didn't have RAID built in (so I would have had to buy an adapter card anyway), and I had read so many warnings against RAID & WHS that I decided that if I went with an external RAID enclosure that connected via eSATA, I'd be guaranteed that it would be 100% hardware RAID and WHS wouldn't know any different (since it's connection was eSATA, that prevents any RAID via software on the host). But as it turned out, that enclosure has another feature besides simple RAID0 and RAID1, it also has SAFE33 and SAFE50. Essentially, it takes either 33% or 50% (depending on which one you choose) of each drive and creates a hardware mirror out of them, then the remaining space is spanned as a single large volume. So WHS sees my two 1TB drives as two drives: a 333GB one, and a 1.33TB one. The former being a mirror of two 333GB partitions on the two drives, and the latter being a span of the remainder of the space on those two drives. It then takes the 333GB volume and splits it between a 20GB system partition and a 313GB primary data partition, and I'm still left with the 1.33TB "drive" to add to the pool. So in this scenario, I've only "spent" 333GB on mirroring, but it actually ends up being cheaper than using two small drives for the OS mirror and a larger drive for the pool, due to the relatively high $/GB of small drives. The only catch is that you have to have an eSATA port that supports port multiplication with FIS switching for the system to be able to see both volumes over the single eSATA link.
