https://zscases.com/products/a4dc-v2 or should I just plug a USB extender?
no, card is 7mm longer and 15mm wider than the cases specified gpu sizeWill this https://www.amazon.com/EVGA-GeForce-Gaming-06G-P4-2060-KR-GDDR6/dp/B07MJDBTD6/ref=sr_1_3?keywords=single+fan+rtx&qid=1638559621&s=electronics&sr=1-3&th=1 fit in the case in the first post?
Can you help with that then?no, card is 7mm longer and 15mm wider than the cases specified gpu size
- GPU support 182mm (L) x 150mm (W) x 44mm (H)
GPU
- Height: 4.38 in - 111.15 mm
- Length: 7.48 in - 189.89 mm
- Width: 2.75 Slots 59mm
