An oced 980 ti is only a few percentage faster overall when both are overclocked and they will still trade blows.980 Ti OC to 1070 OC. 980 Ti is faster.
Price 980 Ti is cheaper by 20-70 bucks depending on what you are looking to compare.
Power 1070 is better.
Heat 1070 is better.
VR 1070 is better.
Since I don't give a crap about the 1070 benefits, I recommend a new or used 980 Ti for 350 or less.
Um no, an oced 980 ti is no faster overall than an oced 1070.
I edited that post within 10 seconds so not sure how you were able to quote me that so fast...Doesn't the 980 ti overclock much better?
Doubt it makes much of a difference anyway...
What does that even mean? If you have bothered to look at any reviews then you would know that the 1080 and 1070 have much less overclocking headroom compared to the 980 ti.I'm pretty sure the new chip will have more window for the OC bro.
The most common recommendation I have seen is "whichever is cheaper".
At the same price, I'd choose 1070, for a variety of reasons (length of driver support, DX12 "If it isn't any better, it can't be any worse than previous gen", power usage, VRAM etc etc).
that's the best answer to me I think. Thanks!Which ever is cheaper!
For $350-$400 get the 980TI
For $430-$480 get the 1070
I see the prices have not come down at all for the 980TI which is crazy! Hello? Time to clear out old inventory! There were some on sale few weeks ago for $350 to $399, but as of right now if the cards are the same price which they are, I checked amazon and newegg, get the 1070.
If you need SLI: 980Ti
If you only need a single card: 1070
The 980Ti drivers are more mature for SLI.
