Just picked up a 9700KF and a Gigabyte Aorus Ultra Motherboard. Using a Noctua NH-U9S for cooling.
I dont have any overclock settings, its basically all on auto with enhanced multi core performance turned off.
Voltage is high 1.416 at times and temps are 99c, causing thermal throttling.
I also still see all cores going up to 4.8 (I thought it should only go to 4.6 with the MCE turned off.)
I tried to set the vcore to 1.2 manually and windows will not even boot up.
Its been since the Sandy Bridge days since I built a new s system, I am kind of stumped on what could be causing this?
Bad Processor, bad Motherboard, just wrong settings?
Please help it you have any advice!
Thanks
Thanks
