I have an opportunity to get an 8800GT 256MB for folding, but I am not sure if the 256MB of memory is sufficient for the newest work units or not. How much RAM is in use while folding?
Should I hold out for a 512MB card or is the 256MB fine?
Does the 256MB card have the same memory system or is it gimped? I think the 512MB 8800GT has a 256-bit memory connection and I think 256MB buffer size would be fine so long as the bandwidth is all there. If it has 128-bit memory, don't get it. If it is still 256-bit, then it is probably ok but I don't know about the newest units.
I can't speak for the 256MB cards but I have a 1GB 8800GT and it performs identically to the 512MB cards with every WU. Now, 256MB is a lot smaller and some WUs do use quite a bit of memory, so you might see a performance hit.
I would say it depends on the price. Even if the 256MB card might incur a performance hit, if the card is cheap enough it might be worth it to go that route anyway. But nowadays, it's not that hard to find a used 8800GT for $50-60, so unless the discount is substantial, I would hold out for a better deal.
yes there will be a performance hit on the 8800GT 256mb cards vs the 512 because the WU will not fit on the cards video memory.. especially if your running windows vista/7 which will use between 75-150mb of video memory.. windows xp uses 29mb with a single display and 49-50mb with dual displays.. (numbers are based off both my rigs at home 1 running XP and 1 running windows 7 32bit.. the WU's will use between 250-400mb of ram depending on the WU...
