Hi guys,
I am using Asrock Z370 Taichi with this CPU and 64 Gigs of 3200 RAM with XMP loaded. As I wrote in the title the CPU wants 1.42 Vcore to run at 5Ghz with offset voltage +70 and LLC-1 in UEFI v.1.30
My questions are - is it too much to use it 24/7? My cooler is Noctua D15 and the CPU is delidded, but in PRIME 95 temps are reaching around 85 degrees C.. The oher thing is that voltage and frequency remain fixed in Windows, despite the fact that I use offset voltage. The frequency also stays at 5ghz. Is this because of the High performance power plan in Windows? I get this even with C1E, C3, C6 and C7 power states enabled in BIOS.
Please, give some insight and share your experience, if possible.
Thank you!
Thank you!
