840 Evo 1TB SSD won't stop waking up
Hooy
After installing my new SSD, my PC won't go Sleep for more than 2 minutes. It always turns back on. I did a fresh install of Windows and it still does it.
I have rapid mode enabled, but that's it. Any ideas?
Bghead8che
I have a Samsung 840 Pro with the same issue. The issue turned out to be the Magician software running in the background. If you keep this from booting at startup your problem may be solved.
-Brian
Hooy
-Brian
Ahhh. I'm just wondering if turbo mode is still active when exiting Magician. I'll have to look this up and try it. Thanks Brian.
evilsofa
Go to the Windows Startup Folder and remove the shortcut for Samsung Magician. It doesn't need to be there; you can just start up the application normally if you need to change a setting.
In Windows 7 and 8, the location of the Startup Folder for an individual user is:
C:\users\%username%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
For all users:
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
Jeremy C
If you used the generic "maximum performance" option in Magician, you'll want to go through and fix your power preferences again. It set my minimum CPU state to 100%, not allowing my CPU to clock down at all. Took me forever to figure out that the Magician software made that change.
RAPID mode is a seperate process from magician, and closing one won't affect the other.
Hooy
For all users:
Edit/Delete Message
Thanks guys, I just turned off Magician and it works like a charm. I didn't see the response about Rapid mode so I did some benching last night and can confirm that it is active no matter if Magician is running or not. However, if you uninstall Magician, it removes the Rapid Mode feature. Hope this helps someone else with the same issues
Nate7311
Rapid mode is a Windows service. Shouldn't need the Magician software running.
