80mm fan hub+blade replacement
GiGaBiTe
I made some replacement fan hub+blade assemblies for a few fans which were accidentally broken or failed due to overheating.
They're a bit annoying to print and require some cleanup with a dremel sanding drum, but work fine in the couple of fans I tried them in. You'll have to reuse the magnet ring and shaft, which may not be universal. 3ds max file included for tweaking.
https://www.thingiverse.com/thing:4008886
