scrooloose said:Its Generic
80GB, 7200RPM, Internal ATA133 Hard Drive
Manufacturer: Generic
Mfg Part #: L06P080
Product Number: 301730
DusterAZ said:It's a Maxtor in a CompUSA box.
k1114 said:I got in on one, and i'll note (as I do in every big maxtor thread) that you should google the hitachi drive utilites and use them to adjust the accoustic managment. Maxtors are by default set to the absolute highest noise (which kills reliability and makes them super loud but lets them advertise better performance) and you can only turn it down just a bit with the maxtor utility. The hitachi one allows (IIRC) settings of 150-290, so I always turn my maxtors all the way down to 150. Performance is still very good.
stealth17 said:thanks for the info! what exactly does it adjust? the rpm?
can you use it with seagates and western digitals?
k1114 said:It adjusts the seek time - you loose a little bit by turning it down, but the tradeoff is well worth it, especially if you have a quiet system.
Not sure about seagate and WD, haven't tried.
k1114 said:I don't know what the stock is on different drives or if the setting represents ns, but I do know that these maxtors are 250 stock. The drive utilites come in floppy or cd image that you boot from, google hitachi drive utilities.
Feature Tool (v1.97)
This is a DOS-bootable tool for changing various ATA features. The Feature Tool allows you to control some of the features of our Deskstar and Travelstar high performance ATA hard disk drives and supports 48-bit addressing, so it will work with the new large capacity drives.
This version adds support for our latest drives. Changes include:
Added new product support
Added SATA feature settings
Added warnings for SATA feature settings
Updated documentation and install packages to incorporate changes
The Feature Tool allows you to:
Enable or disable the read-ahead or write cache.
Change the drive Automatic Acoustic Management settings to the:
Lowest acoustic emanation setting (Quiet Seek Mode), or
Maximum performance level (Normal Seek Mode).
Change the predefined capacity of the drive. This option can be used in situations where there is a BIOS limitation and the drive is not recognized. See the Users Guide for specific details.
Switch the Ultra DMA mode
Change Advanced Power Mode - allows you to change between the lowest power consumption and the highest power consumption (maximum performance level).
Show Drive Temperature - shows the current drive temperature in Celsius and Fahrenheit.
Configure SATA interface - adjust maximum speed and enable/disable Spread Spectrum Clocking.
k1114 said:Yes, that's it. And yes, it changes the setting on the drive so it will stay even after you format it or whatever.
