Randall Stephens
- Mar 3, 2017
Did not realize that, thanks.You’d be surprised how much resources modern mainstream Linux distros use. Better than Windows 10, but not by as much as you’d think.
My goto lightweight Linux distro used to be CrunchBang Linux, they closed down in like 2013 and BunsenLabs that was started as a continuation project was looking pretty good for a while, but they haven't released a new version in like 2 years now.
Maybe I'll give Lubuntu a try.
A shot in the dark, but at one point i changed a bios setting for OS from Windows (default) to "intel linux". Same thing, could not get back in. Had to pull battery to reset settings and made a not to just leave that setting alone.I don't know what the hell I changed, but I cannot get back into the BIOS no matter what I try anymore...
Used a thermal pad and some electrical tape to fit a full length ssd in there. Not a lot of room for it to come loose but gave it a good shake test to make sure.Yep. Disconnecting the battery for a few seconds got every with the BIOS reset and I am able to get in again. That was annoying...
Unfortunately I discovered that there is no mount for longer mSATA card where the LTE card sits, so I left all that alone for now.
MSATA or m.2? if the latter I might get one of these to play around with!mSATA card where the LTE card sits
It's m.2 ...MB key if memory serves. Made a noticeable difference in speed slapping a new drive in it.MSATA or m.2? if the latter I might get one of these to play around with!
Edit: Make a mirror of the stock drive. Made the mistake thinking a fresh install would be a good idea and now can't find some drivers.
So after all the tinkering I've done, I've come to the conclusion that Windows 10 is probably the best option for just about everyone with this dumb thing. The onboard USB based wifi is annoying to deal with in Linux and it's performance kinda sucks, and it took way too long to get Intel 500 Audio to work in Linux. The eMMC storage is also pretty terrible.
So being that the only real way to improve the performance of this laptop is to either sacrifice the PCIe LTE card for a different Wifi card or SATA storage, I feel that swapping in better storage and dealing with Windows 10 is the least terrible option for most people.
So ridiculous I bought a second! I do a lot of projects that use RPis but those are hard to find these days.. this thing is a more than worthy replacement for a pi!fyi, the price is $60 now. Ridiculously cheap even if not perfect.
Crazy.... Shame they won't ship emfyi, the price is $60 now. Ridiculously cheap even if not perfect.
That's very odd, I was able to watch YT videos with audio immediately without any changes. A few possible things come to mind:Ok. Same results as every other Linux distro I’ve tried.
Builtin wireless works after manual patching, audio does not.
I was only able to get the audio working once with Linux and it immediately broke after rebooting. I cannot for the life of me remember what the hell I did and I’ve never seen it work out of the box.
It only wants to output to a ‘Dummy Output’.
My bios settings are stock except for disabling the CPU power limit. I had the same problem with the Intel Linux setting so I left it on Windows.What BIOS setting have you changed? I tinkered a bit with the CPU thermal settings but that’s it.
The only other one I messed with was the OS type, I changed it to Intel Linux but was unable to boot off USB after that. I ended up having to take it apart and disconnecting the battery to fix it.
I’m running Mint cinnamon too. I don’t see how KDE would make a difference.
It works under windows.My bios settings are stock except for disabling the CPU power limit. I had the same problem with the Intel Linux setting so I left it on Windows.
KDE shouldn't make a difference, I just threw that in there because I generally recommend it since it uses less memory.
I'm stumped why it doesn't work for you. Maybe the audio hardware is defective? You said you got it working in another distro with effort though, right? So idk..
I tried Ubuntu 22.04 today and audio worked right away. Very odd. Also somebody else commented on the YT video saying they had the same problem with Ubuntu. The only explanation I can think of at the moment is that there are slightly different hardware revisions with different audio chipsets? No idea. What audio chipset does it say in Windows for you?It works under windows.
Thanks for the info, this pretty much solves the question of why. There indeed are two hardware revisions with different audio devices.I just picked one of these up at the Chicago Central store after work. I don't see anything on the box that will show if it is a V2 or not. Unfortunately I got a V2.
Under the Windows Device Manager it shows the audio device as ESAuDriver Device. Under Hardware ID it shows ESSX8336.
Google searches show that support may be coming but could take a while: https://askubuntu.com/questions/1375830/no-sound-everest-essx8336-sound-card
Of course I'm not much of a Linux person and have not searched too much yet....
edit: another link with some info: https://bbs.archlinux.org/viewtopic.php?id=272060
More info:
The store I was at had a wire basket/rack thing roughly the size of a standard pallet full of these things. Full as in stacked around 4 feet high. They had a buttload.
The boxes are all sealed with tape, so no, not appropriate to open boxes until you find one that is not a V2.
You have to just roll the dice. At this point there may not be any left that are not V2.
Store onlyAre these store pickup up only or will they ship them as online orders?
Also a timy bit of esd foam between the lid and the ssd couldn’t hurt.Used a thermal pad and some electrical tape to fit a full length ssd in there. Not a lot of room for it to come loose but gave it a good shake test to make sure.
They can be shipped, but standard shipping for me is showing up as $19.85Are these store pickup up only or will they ship them as online orders?
I believe it's 1.4 as I was able to get 4k 30hz. Also keep in mind it's a mini hdmi port not a full sized one.Anyone who owns it, what is the max output of that hdmi port - hdmi 1.0, or 1.4?
I suppose you could also use display link on tat USB 3 port to get 4k putout?
It still shows as 'reserve' for me. I ended up buying a used 3 in 1 laptop locally so I'm good.They can be shipped, but standard shipping for me is showing up as $19.85
Just figuring out how capable this sixty dollar wonder can be if suddenly necessariy
I know that broadwell supports 4k, but that doesn't mean that the discount bin device here does also
How exactly did you disable the power limit, and did you notice any improvement from doing so?My bios settings are stock except for disabling the CPU power limit. I had the same problem with the Intel Linux setting so I left it on Windows.
