[RCKY] Thor
- Oct 1, 2001
Those are the important ones. Clears the caps with no problem, rests against the drive cage. Might be under a little bit of torque, but if it is, it's not much. 5886 3dmark06 at stock clocks, never broke 65 degrees on the card. Doesnt seem to put too much heat out the side of the heatsink by the cpu (finger test method ) and definatley moves more out the PCI slot.
Rest of the pics are here: http://test.air-power.us/gallery/7900
and I got this to go with it: http://test.air-power.us/gallery/Viewsonic
