Been working on fitting / cutting a 700D to accept a PA120.4 under an Koolance shroud. I already purchased gentle typhoon fans to use. The problem I ran into is when I piece together the shroud, fans, and radiator the top of the radiator is the same height as the case cutout. This leaves no room to run the wires for the fans inside the case. Keep in mind the shroud and case cutout are the same size.
I took this pic from WozniakMac showing what I'm taking about. Except WozniakMac used 55mm fans which drops the radiator down, but I've see others use 25mm.
http://i193.photobucket.com/albums/z287/dguyse/2010-09-07_13-19-06_646.jpg
Any idea's?
Any idea's?
