I'm a bit confused about the maximum bandwidth available to each device on an SATA channel. In the pic below, taken from the eVGA manual for a 680i SLI board, it shows that there are 2 channels assigned to 3 different controllers:
2 Questions:
1) In this case does each controller or each channel receive the full 300MB/s?
2) If you are setting up a RAID 0 stripe using 2 drives on this board, would it be better/faster to use channels on the same controller (SATA 1 and 2) or channels on separate controllers (eg. SATA 1 and 3)?
Thanks in advance,
~Aux
2 Questions:
Thanks in advance,
~Aux
