Phazedplasma
- Jan 29, 2004
How much of a performance hit will i get since its not and AGP 8x slot?
Monkey34 said:It MAY work, but for the money he'll spend (probably 300-450$), he could get around an Athlon 2600, a mobo, and an ATI 9700 or 9800 pro. Might have a little left over to go towards 512mb of ram if he's a good buyer.
The overall upgrade will be a better performance boost than just a top video card in an old system.
quoted for truthElios said:it wont fit and the voltage will be wrong look at the keying on the 2x slot and then look at an 4x-8x one the key is more to the back of the slot on the 4/8x
The[H]uman said:well why you would waste a card that costs that much in a board that old which means the cpu and everything about it is going to bottleneck the performace of the card but whatever i guess .. it's going to take a big hit
drewb99 said:I had a Ti4600 that was stuffed in an AGP1 slot for the longest time without a hiccup, but meh, I wouldn't try your luck.
