thats a nice score but the heat output is pretty high, what kind of heatsink are you using on it or is it stock?nova[11] said:results for my BFG 6800 GT OC so far. I haven't tested the max but this is what I have so far.
Core: 420 mhz
Memory: 1.10 ghz
Idle Temp: 62 c
underload: 68-69 c
post up what you are getting with yours
yup thats on the BFG stock cooling, this was barely bumped up from the auto detect.tornadotsunamilife said:thats a nice score but the heat output is pretty high, what kind of heatsink are you using on it or is it stock?
Jerry1978 said:will a card running at those speeds and with that heat last for very long? i'm always worried when OC'ing that my card will be OK for a year but then die.
oozish said:well, what would happen is you'd see artifacting and visual problems before the card just died or anything, but mainly what heat/overclocking does is shorten the lifespan of the card through. If you get a new card every 3-4 years, I wouldn't worry about it.
