6700k wont go over 4.4Ghz?!
Emig5m
[H]Lite
I must be the most unluckiest person on the planet with winning the silicone lottery and I also must have the worst 6700k on the planet. Even 1.40v doesn't improve stability over 4.4Ghz. Seem like in Core Temp when it crashes over 4.4Ghz it's core #3 (numbered #0, #1, #2, #3) that drops from 100% utilization down to 24%. Doesn't matter if it's running at 4.5Ghz, 4.6Ghz, up to 1.40v, etc. Does that mean that only one of the cores is holding my chip back since it seems like it's always core #3 that drops from 100% usage running Prime95? (will also crash in game) I'm running it on a Asus Sabertooth z170S with a Noctua NH-D15S cooler - is it really possible to get a 6700k that doesn't do over 4.4GHz stable? Is there any setting in the bios other than upping the voltage that I could be missing to improve stability?
janas19
That's just barely below normal. Most of the Skylake chips max out at 4.5GHz-4.6Ghz.
THRESHIN
Yeah I got a 6600k and I can't get beyond 4.4....but I also have cooling issues. Long story.
zpackrat
yeh, my 6700k was comfortable all day at 4.4Ghz, but anything above required too much voltage and was never used for more than benching. Delidded even!
Emig5m
[H]Lite
So I probably wont even bother to delid it or anything and just leave it comfortably at 4.4Ghz.
freeagentt
[H]Lite
Did you max out your duration timers and plane current limits? I couldn’t get my 3770K over 4400 until I maxed those out. I also can’t run an adaptive oc over 4400, it’s gotta be fixed at 1 voltage, 1 clock. Should be able to get a few hundred MHz more..
