Hi,
I just built some systems with asus z170 sabertooth mark 1, i7 6700k and 64gb of G.skill 2800 ddr4. Cooled with an H100i GTX. I planned on a mild overclock to 4.5.
Based on reading hear and elsewhere it sounded like getting the ram at 2800 was going to be unlikely. Other people / reviews showed pretty high cpu voltage and temps required to overclock up around 4.7.
Settings I used are below. I'm using adaptive mode without really knowing why, which probably isn't smart. Except it seems to working very well.
So far I have only stress tested with XTU, cinebench and handbrake. So, a couple of questions: I'm not clear how to test with handbrake - I just found a dvd iso and converted to MP4, took about 3 hours. Cinebench gave great scores as well.
But, I'd like to stress it harder. I read that prime95 or aida64 aren't as good for testing skylake, but I have no way to know this. Maybe I don't even need 1.32 volts? What's a better way to ensure a stable overclock here? Stability is the most important thing for me. Also, temps on the 6700k are max at 60 on coretemp. Which seems lower than others report. i.e. I'm suspicious why everything was so easy.
I used the following settings:
Ai overclock tuner = manual
BCLK freq = 100 mhz
Asus multicore enhancement = disabled
CPU core ratio = sync all cores
Core ratio limit = 45
CPU core/cache voltage = adaptive mode
Offset sign = +
Total adaptive mode CPU core voltage = 1.332
DRAM voltage = 1.35
DRAM speed = 2800
CAS 15
RAS 15
ACT 35
BCLK freq = 100 mhz
Offset sign = +
DRAM voltage = 1.35
DRAM speed = 2800
CAS 15
RAS 15
ACT 35
