I started to overclock my 6700k. Been using a H100i with ML120 fans on it.. usually idles pretty low like 23-25 ish give or take a few degrees. I set my multiplier to 46 and voltage to 1.350 and at full load was seeing temps at 85C which obviously is not good. I do not understand why the cooler has the temperatures so high. With a cooler like this at that voltage. I am inexperienced however though and am wondering if the voltage is high for that multiplier with a 6700k.
I am assuming something is wrong, although I am using an Evolv and the CPU radiator is on the top and has very little airflow.
