64GB PNY Attaché 2 USB 2.0 Flash Drive - $6.99
zombielando
It's an awesome price for 64GB of storage, would be great for plenty of emulator storage for a pi. Thanks Mezner.
Zepher
[H]ipster Replacement
How many days does it take to put 64GB of data on it?
ccityinstaller
SixFootDuo
Forgot to mention if you buy Microcenter thumbdrives and they go bad they have a life time warranty. I've replaced one already that was nearly two years old.
I'm using one of those micro 64gb USB 3.0 drives that were around $23 at Xmas.
Vatican
I am glad you have had good luck with these. I have had nothing but issues with the MC USB 3.0 drives. They are slow' and Windows is picky about seeing them. I use them in only Intel based USB ports and have had the same results on several systems.
What speeds do you usually get? I'm getting 120mb/s during transfers and had no issues thus far. As someone else mentioned though, you can easily exchange these if they go faulty.
Slystealth
OMG DO NOT ORDER THESE , TERRIBLE TERRIBLE. I HAD OVER A DOZEN FAIL ON ME! THEY ARE SUPER NOTORIOUS FOR FAILING UNDER A WEEK! JUST A WARNING IS THE REASON I AM TALKING ALL CAPS!
Gorilla
Did it really? I ordered a PNY 64 gb usb 3.0 flash drive for like 12 bucks a few months back from tigerdirect. I doubt this was a pricing error. Strange.
Their email to me said they ran out of stock and would not be getting more. Everyone on slickdeals thinks it was probably a mistake and this is just TD pulling the same old crap.
Slystealth
Good , your ordered got canceled , these are crappy thumbdrives and not worth time/money
