Are there any Athlon XP motherboards out there with 64 bit PCI slots? I'm trying to put together a small/cheap file server for myself and I couldn't find any boards like this after searching pricewatch. Thanks for any info.
*PCI extended- Longer, but not that same as 64-bit PCI...not sure what its used for. I do have one NIC card that will fit in this slot of a standard, but not a 64 bit slot.
*64 bit PCI - I want one too for ym RAID card, and SCSI card. (this is the real PCI-X, even thought many people call PCI express PCI-X) i think...
That's not quite correct. Standard or conventional PCI comes in 32 and 64-bit flavors, and each can be at 33 or 66MHz. Then there's PCI-X which is PCI-eXtended, which is 64-bit and can be 33, 66, 100 or 133MHz. Finally, there's PCI-Express (PCI-E).
ZMTToxics, the OP was asking about Athlon XP boards, not AMD64.
