Latest from the rumor-mill is around May 2012 for Kepler.
ATi is rumored to be releasing October'ish
But with that, what game cant your GTX 570 run? Besides Metro 2033...(and even that it can run fairly well)
Feb 27th, 2012 10AM PST
10 years...
Anybody else think they may be releasing these things a little too close together?
My beloved 5870 for example was the top dog not even a year ago, now its mainstream. So what? I paid $200 for it back in January instead of the usual $400 and I can still max anything at my resolution. Ive looked at maybe a 6970 but for only a few fps increase and $350 price tag, I cant really see a reason.
So if the higher end 6000's arent that attractive, and my 2 year old card will play anything out today, it just seems a little soon to be tossing out some 7000 cards.
AMD's 7xxx series will suck because its basically gonna be a refresh of the 6xxx series which was a refresh of the 5xxx series and yet again a refresh of the 4xxx series. Actually the strongest shader performance was from the 4xxx series., a 800 shader 48xx killed a 800 shader 57xx and the 800 shader 6xxx series sucked too..
THE GTX 680 WILL BE AT LEAST 2X FASTER THAN A GTX570.
The 69xx series was not a refresh of the 58xx series, they completely changed shader architectures. However it was not the full-fledged product originally envisioned as they had to cut it down to fit 40nm as TSMC's 32nm node, which it was intended to be produced with, was cancelled.THE GTX 680 WILL BE AT LEAST 2X FASTER THAN A GTX570.
The 7000 series should be significantly faster than the 6000 series.
All companies typically release a new product, revise / refresh it, and then release a new architecture, more or less. NVIDIA's 400 and 500 series, for example.
I smell sarcasm...
If not, HD 5xxx series a refresh of the 4xxx series, rofl my damn copter. an HD 5870 wiped the HD 4870x2. The 6 series added more Vram and much better crossfire scaling.
I wonder if this will be another 8800GTX type of card/series or a GTX 4xx type, hoping for the former.
No.
The 6000 series was just a rehash of the 5000 essentially. The chip became a bit more efficient but it's still on the 40nm process. For the 7000 series they're skipping 32nm entirely and going right into 28nm, on top of a new architecture. It should be a giant leap in performance over the current cards.
Someone must have been sleeping through the Radeon HD 6770 & 6750 launch.Or sometimes they just Rebadge them like they are new...
infact we haven't seen any rebadging lately, i wonder if Nvidia will start again or maybe to try and catch up to ATI (if they do release in october) they will skip the 600 series and goto 700
AMD DOESN'T REBADGE ONLY NVIDIA!!!!111@#$#@$#!!!!
Please tell me this is sarcasm!
It obviously is.
oh so this is where all the trolls went
I would expect to see a lot of PCI-E 3.0 motherboards with additional molex or other 12v power connectors to the motherboard so that 3x/4x loaded cards don't burn out the 24pin connector. Some already do this, but I bet it will become more common if future cards try to draw 150w from the slot.Besides, the strongest point to the new cards is that PCIe gen 3.0 is approved. The new cards will likely fall under that spec and be backwards compatible to gen 2.0.
The Gen 3 PCIe doubles the rate as well as increases the power available, from 75W up to 150W(? cant remember exactly) The new card would need to have a power connection for gen 2 slots, but maybe not for gen 3. Reduced cable clutter!
And yes, I am aware that current cards dont max the bus, but think about it. A 128 bit that would be as fast as a 256 bit is now.
