You can get displayport to DVI adapters but decent (active dual link) ones are like $70+ each. Regardless of which way you go NV or ATI you will have to buy adapters as NV SLI has 4 DVI outputs, AMD (5xxx) only has 2. The rest will have to be displayport.
the 6 DP 5870's come with the DP to DVI adapters but i think they are the single link version(1920x1200 and lower resolution)
otherwise your best option if your not a gamer is a pair of these cards:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102870
