LanceDiamond
- Oct 11, 2005
Ok, I did better with my Google-fu on this one...
My previous card was a BFG 260-896OCE. The BFG says it's "HDMI Capable" which, when I installed that card concerned me a little. HDMI Capable, as it turned out, meant the card came with a small 2 pin cable to connect to a soundcard internally. Once I connected that cable, I had sound via my HDMI display (a Vizio 37in LCD TV) and the PC speakers at the same time.
So...all was well and the Vizio had surprisingly good sounding speakers. Often, if I was listening to music I'd turn the Vizio on in addition to the PC speakers+sub and it sounded very good.
Upgrading to the 5870 has apparently cost me the ability to have the same audio coming from the PC speakers and the LCD TV at the same time.
The 5870 has no need for a plug on it for HDMI audio. It installs a sound playback device called "ATI HDMI Output". This device winds up being set to the default during install of the Catalyst drivers. So right after installing Catalyst, I had no sound at all through the PC speakers. Going back into Playback devices and making Speakers the default fixed that but stopped audio from the 37in LCD TV speakers.
Thankfully, PowerDVD allows you to specify it should use HDMI for playback of Blu-Ray movies. I can't find anywhere in Media Player under Vista to specify that but I read that Windows 7's Media Player does allow it. Vista Media Player just plays through whatever the default device is - either Speakers or ATI HDMI Output - but not both.
From what I was able to find via Google, it seems Windows does not support simultaneous output to multiple playback devices, despite demand for that feature. Guess I had it accidentally with the BFG card because it was just pulling audio straight from the sound card and sticking it on the HDMI cable.
I am liking the 5870 and trying to figure out what I'll do with the added display flexibility but having audio output from the HDMI display and PC attached speakers (X-Fi attached to Bose w/sub) at the same time is a feature I may miss. I do now have the ability to have two different audio streams going but that just means they drown each other out.
