5600x max PBO boost lock.
AVATARAT
Does anyone know why AMD has locked the maximum PBO boost to 5600x with AGESA 1.2.0.0 and the same with 1.2.0.1?
I mean, if I flash with these BIOSes, my maximum boost can't exceed 4850MHz never mind what settings I choose in the BIOS.
I asked in the AMD community site but still no answer :(
I know that I am not only one that have this problem.
Makaveli@BETA
What maximum PBO boost lock?
i'm on Agesa 1.2.0.0 now and with PBO2 + 200mhz + CO
i'm doing 5.05Ghz Single core boost stock on the 5800X is 4.85Ghz.
AVATARAT
If I flash with new BIOS higher than current I can't reach more than 4850MHz never mind what settings in BIOS I use.
I know a few people that experience the same problem as me on different motherboards.
Asus answer me that the CPU (5600x) work within AMD specifications 4600+200 PBO so everything is OK for them. And if AMD made any changes with AGESA they are not responsible for that.
So the problem is only with 5600x CPU.
aldamon
I guess this is a "rich person" problem so to speak. I have bronze silicon on my 5600x and can barely do 4.6GHz without occasional BSOD.
AVATARAT
How much CCX do you have in your 5600x one or two ?
You can check it in Ryzen Master.
This with 2 CCX it's possible to cannot go over 4.8GHz. Otherwise you can try the lastest BIOS with just auto voltage + PBO.
Or to try to lower your RAM speed to 3000Mhz because you use 4 sticks.
Or just to try with 2x8GB RAM.
At all, BSOD mean a problem.
And to be clear I talk about CPU PBO boost, not fixed clock by multiplier.
aldamon
Yeah, I've tried everything. It's just not worth any more effort with silicon stretched almost to its limit at stock. I think at my current settings with PBO2 and tiny bit of curve, I get all-core boost in the 4.5GHz range with Cinebench. Best case scenario I keep fooling with it and get 8% more performance..sometimes. Not worth the time like old days of OC.
AVATARAT
If the CPU do not work in it's specifications you can open a ticket and to try to RMA it maybe ?
