Falling Anvil
- Nov 3, 2007
Hi, I'm a recent lurker turned brand new member.
So, I had recently purchased a Corsair 550VX PSU. Great unit, rave reviews and very cheap when I got it. I had a month and a half old Dell Inspiron 530 that I intended to use it on. Looking back, at the time I brought it I had debating building my own system but the a $350 dollar coupon had swayed me towards it, but that's a discussion for another day. Anyway, I had wanted to replace the OEM 305 watt PSU that had come with the system so I could have more power and more efficiency and perhaps a bit more quiet as well. I had never done upgrades of this sort(only had helped change a video card and wireless networking card) but was willing to try and had done weeks of research so I felt it was ready.
Anyway, after some 2-3 hours of struggling to fit it and it's cables into the provided MicroATX case with some bleeding thrown in (so should have gotten modular for this), I had managed to get it working. Worked great, but the giant mass of wires from some very long and thick sleeved cables in the upper front of the case disturbed me. I had wanted the vent holes in the lower frontal part of the system open for airflow, but had also wanted less clutter in front. So after a full day of operation I opened the case again and attempted to use the provided zip ties to try to corral the wires together. Unfortunately I had gotten cocky and failed to turn off and disconnect the PSU, probably my first mistake. The second mistake was the zip ties, they proved worse than useless and I had a hairy moment where I had to take out a too-tight ziptie with a boxcutter and a scissor near a middle SATA connector. Fortunately there was just a notch and no other damage it seems.
In any case, in hindsight it *seems* that my moving of the cabled mass had disconnected the 24 pin connector while I was jumbling the wires around. When I had given up and reassumed the wires in the same position as before, I found that the computer would not boot, the activity light provided with the motherboard not turning and keeping itself on. A few subsequent tries to move the connector cord (which seemed to influence whether the light and thus the mobo turned on or not) around to get the light working and boot was done until I could finally get light working. When it went back on for good and I tried to boot however I got the sound of electricity buzzing a little. I investigated after a few tries, which yielded me the loose controller. Unfortunately doing so was a bit too late for my poor motherboard and when I booted again, I got an error about the diskette drive 0(I assume the HDD) not being read, however an F1 continue yielded success so I know it wasn't just the HDD. After a few more tries I could get through to the startup screen for some reason with pretty fair regularity past the HDD error. All in all, after the error in the beginning and 3 lost megabytes of ram all seemed well.
It was only when I reexamined my motherboard did I find what I think is the culprit. Capacitators, busted ones, all over the motherboard. Not all are bulging but enough are to make me not want to turn this thing on until it gets fixed or replaced.
Now, this is the dilemma. The motherboard is probably a lost cause, I'll call tech support to see if I can get it fixed or replaced(probably won't work). What really interested me is the power supply, which worked like a champ even after the caps were busted for the short few times after I had it on, including a half hour or so stretch of web surfing to test it in the morning. If the caps on the motherboard are busted, what about the stuff on the power supply? On the other hand, it was doing what it was supposed to do, the wires and my blunder being the real culprit here. I also don't have any equipment on hand to test it out so the only way to know would be a year or two from now and whether I get all my equipment destroyed from ripple and the like or not. I know we have Corsair personnel here so they could help fill me in on this(and of course many other more knowledgable than I) so here's the question, after having read or skimmed all that song and dance, would I be able to properly reuse this PSU at a later date?
Thanks in advance for any answers, and a greetings to everyone on the [H]ardocp forums!
