Since all i3 SB laptops suck and you can't even run F@H on their HD 3000 gpu, I'm done trying to fold anything on their sloppy 2C/4T/HD graphics design when this WU finishes. A SB i3 laptop will net 500-1000 ppd when it comes to i3's LOL! Usually LESS! Pic. I'm racking up like 342 PPD right NOW OMG on this junk!!11!
For the same money you can get an A6 Fusion. Which has 4 cores and an AMD GPU which pulls almost 2x the FPS of an i3 HD 3000 in CB 11.5 rendering tests. As well you can FOLD on 4 REAL cores and the AMD 6xxx series GPU.
When I fold on the A6 APU my CPU and GPU temps are around 68* and the CPUs limit is 105* I wonder if there's any free MHz on this chip without adjusting voltage, same with the GPU looks like it runs @ 400MHz anyone with a Llano get any extra out of their GPU with minimal heat I'm thinking 500-600 should be possible on the core but I never experimented with a mobile GPU. Advice is welcome. tia
Oh yeah i3's sucks all kinda butt compared to AMD lawl!
If anyone wants specific testing/bench done against these 2 lappys I will, and both these laptops run 500.00 USD. So far the AMD wins in CB single thread and MT but the i3 is clocked low, but for 500 on each I dunno how Intel sells these things against AMD I guess there's a lot of uninformed idiots out there. Then factor in lmost 2x as fast GPU performance, and wow Intel has brainwashed masses of people it seems.
Let's see how they compare I'll update with Test Scores daily.
